07-19-2014 03:20 AM
Dear,
I got 4 Pwm input like picture below.
I try digital count, also digital input with timestamp but not be able to catch them correctly.
Is there any possible solution for this problem?
Thanks alot.
07-20-2014 08:43 PM
Hi there,
If you want to do the edge counting for any purpose
You can try with DAQ assisant function and setting the Counter Input section as Edge Counting
Or with the more flexible DAQmx API:
Are you going to measure the digital count for 4 Axes sepearately? Because there's only one counter available on MyDAQ device:
http://www.ni.com/pdf/manuals/373060e.pdf
07-21-2014 10:04 AM
Thanks Wranky, I try DAQ assistant before but there is only 1 counter.
