MyRio I2C Hitechnic DC Motor Controller for Tetrix - Read Problem
We are working with Tetrix and the MyRio for the WRO college level competion.  I have tried just about everything I could think of but I can't explain why I'm getting random garbage when trying to read registers on the DC motor controller through I2C.
I have followed the Datasheet provided by HiTechnic and I don't understand why I can write to the motors to get them to move, but I can't read anything useful from the Registers?
Even constants in addresses 08~0F which is supposed to list the manufacturer "HiTechnc" or "48 69 54 65 63 68 6E 63" and addresses 10~17 which is supposed to list the Sensor Type "MotorCon" or " 4D 6F 74 6F 72 43 6F 6E" is returning a random sequence of bytes each time any of those addressed are read.
I hope someone has encountered this before, because I'm running out of time to fix this.
Marco
(6,603 Views)
I'm more familiar with the 845x driver than the myRIO Express VIs but do you get a constant return if you just read one byte starting at 0x00 when the Express VI is just configured as Read (not Read/Write)?
(6,580 Views)
Hi Matt,
If I just read without writing I get a random number, without writing I can't specify which register to read from.
I contacted the people who made the unit and they told me to slow down the fcl down to 10Khz.  I don't know if or how that can be done as the CNTR register only supports u8 and the value needed I calculated to be 2013.
Marco
(6,564 Views)
I didn't quite understand this, was this a mistype of "slow down the scl down to 100khz"?  Can you also explain your concern about CNTR register.
(6,550 Views)
