01-03-2016 08:44 AM
I am trying to play a MLS sequence over my myDAQs left Audio Out channel, since I want to play it over a loudspeaker.
I am generating a MLS sequence of a certain length and would like to write the samples to the DAQ output channel, but I am not hearing a sound so far. It works when I use the express DAQ assistant, I would like to use a chain via Measurement I/0 though. Can anybody tell me what I'm doing wrong please? I have attached the file. Please excuse the quite spacey layout, I have tried to make it work for the last 3 hours and tried many different things and created a lot of room. I would appreciate any help. Thank you!!
01-04-2016 06:18 AM
Hey Ribbster,
the VI doesn't look very beautiful, but it should work with your myDAQ device.
I can't find an error in the programm at first glance.
Do you receive an error during the execution of the VI?
Can you attach a VI with the express DAQ asistant?
Regards, Stephan
01-04-2016 06:58 AM
Thank you for replying Stephan! It doesn't look beautiful at all but the vi started out far more complex and I was narrowing its malfunction down over 3 hours and became tired of making it look neat, I just wanted it to work.
I can't believe it myself, but it works all of a sudden!!! I should add that I am using labVIEW through a virtual machine, it works most of the time, but the myDAQ is not very reliable with it. It just seemed to have needed a restart!!
