07-02-2019 06:23 AM
Please I need the name of a specific accelerometer type that is compatible with Agilent 34970A data acquisition/switch
07-02-2019 09:03 AM
The 34970A has a max samplerate of 500SPS.
So it would be fine for acceleration signals up to 200Hz.
Kister (and maybe others) build accelerometers with signal conditioners that put out something like a bandlimited RMS value proportional voltage .. I think even with a peak hold .....
What do you want to measure?
(Maybe the soundcard would fit better? )
PCB/Synotec/Modalshop/?? have an accelerometer mit USB connection that plug in as an soundcard.
piezoelectric accelerometers are commonly used together with an charge amplifier, or have it build in (IEPE) an need a constant current source of 2mA-20mA ..
But there are a lot of different types ... so bandwidth, range , size, weigth, mounting are needed informations for a recommandation.
08-22-2019 03:30 PM
Please, I want to measure acceleration using ADXL335 accelerometer sensor with agilent34901A and labview interface. Please how do I couple my accelerometer with the agilent.
08-22-2019 03:55 PM
Hi, please how do I couple my ADXL335 accelerometer sensor with Agilent 34901A so as to be able to take readings from my labview and recalibrate the sensor. Please it's urgent. Thanks
08-23-2019 01:37 AM
Naked sensor chip or demo board?
You need to power the Chip (3V, maybe two AA cells?) , choose a filter capacitor (aliasing , see bandwidth of your 34970A, and needed bandwidth for your measurement) and connect it according to the ADXL335 datasheet.
08-23-2019 08:09 AM
It's a sensor chip on breadboard, I'm just hoping it's compatible with Agilent34901A. Meanwhile I will check the datasheet for the connections.
