04-12-2015 08:16 AM - edited 04-12-2015 08:19 AM
Greetings!
We are working on Voice processing using myRIO to implement a system that detects a command given by the user. The command simply is an aplhabet for the ease of implementation. We want a unique factor that distinguishes four alphabet commands. We don't want to convert it to a text output or do anything complex. Please guide us as to how we can proceed.
Thanks in advance and eagerly waiting for help..
Venkatesh
04-12-2015 08:37 AM
You need to be more specific in your question. Show us what you have try and tell us where your difficulties are.
Michel
04-12-2015 09:12 AM
We tried implementing the VI (attached). The problem we face is that the final value obtained in the VI (x*y) is not lying in the same range for a particular alphabet input. Can you suggest to find a parameter that can be used to control the wheelchair when an alphabet command is given to the system.
