myRIO : 4 wire compact camera
Hi
I am having som trouble wiring and programming a compact camera with myRIO.
How should I connect the camera with the myRIO? Is this the right way (wiring diagram) if the change the arduino with a myRIO?
And which blocks shall I use i LABVIEW, so I can view the image from the camera? In the end myRIO should be able to detected fire.
The only exampels I can find on the internet is with USB cameras.
\\Lars
(5,434 Views)
Hi LS89,
Your camera seems to connect through TTL serial , unfortunately, I do not think that this camera is supported by National Instruments software.
http://digital.ni.com/public.nsf/allkb/4331B4AA3AE95233862574C200539A2F
If you are however looking to connect any other type of camera to the myRIO through ethernet , here is a method :
http://digital.ni.com/public.nsf/allkb/F6C8900A69CEA9B986257C9E0064B02F?OpenDocument
Mark
Applications Engineer Intern
National Instruments UK and Ireland
(5,378 Views)
