webservice Invalid server IP error
I created a myrio project and tried to create a remote access using web publishing tool. After creating the HTML I followed the procedure of creating a new application and run it up as startup .... At the end after the myrio restarts and I try accessing the webpage, it shows the error "Invalid server IP"
What might be the problem?
I followed this turorial for creating the application
http://digital.ni.com/public.nsf/allkb/AB6C6841486E84EA862576C8005A0C26
(5,585 Views)
Hi yas87,
Are you using LabVIEW 2009 or earlier?  If so, the following KnowledgeBase article may answer your question: Invalid Server IP Address When Trying to Access File Created By the Web Publishing Tool.
Kelly B.
(5,560 Views)
I am using Labview 2014
(5,553 Views)
Hi yas87,
Can you confirm that the Application Web Server is enabled?  Also, I would recommend disabling any firewalls on your PC to make sure they are not interfering with the connection.
Enabling the Application Web Server for Web Services
Kelly B.
(5,546 Views)
