Say I have profileA which calls sequenceB which calls sequenceC. sequenceC needs to access UserChannelX defined in the system definition. Currently, the only way to do so, I believe, is to pass UserChannelX into sequenceC as a parameter which means it needs to be defined as a parameter in sequenceB as well, even if it's not used in sequenceB. This greatly increases the number of arguments of a sequence which may never be used but is necessary in order to give the lowest sequence access to system definition channels. It seems like we should make sytem definition channels directly available at any subsequence level (sort of like how global variables can be referenced anywhere). Thank you.
