Advanced Plotting Toolkit
Draw polar scales for negative magnitude
Hi all,
I just started using this toolkit for a series of polar plots. Creating these plots I found that negative magnitudes (Y-axis data) are drawn correctly but the circular dotted scales are not drawn at all. I would like to see these scales below zero magnitude as well. Has anybody have any idea how these scales below zero magnitude can be drawn?
(431 Views)
Hi all,
Problem is already solved by using the "Set Y-ticks" VI in the library! Works well!
(415 Views)
