Automotive and Embedded Networks
Power for NI 9862 within cDAQ 9178
I would like to know why an external power is required for the NI 9862 CAN module within the cDAQ chassis. This chassis is already supplied with an external power. I don't want to install a further power supply specially for the CAN device. Is there any possibility to connect the 9862 with the cDAQ power supply?
(3,661 Views)
You think that is bad?  Try having a LIN transceiver in the 9860.  Then you need to power the chassis with 9-30V, power the card with 9-30, and then power the transceiver with bus power which I can't remember the range of.
Anyway the answer given there (which I think applies here) is that the card needs to draw more than the specified maximum power that a single c-series card can draw.  So to power the card an external power needs to be provided.
(3,643 Views)
You won't need an external supply if connected to the OBDII connector on a vehicle. The vehicle bus will supply power.
(3,632 Views)
Okay, thank you for the answers. I think the solution for me will be to disconnecting the power suppy cable from the cDAQ and reconnect it to the cDAQ and the NI9862 in parallel. Only 6 of the 8 slots of the cDAQ are used, therefore the power consumption should be okay.
(3,622 Views)
Sounds like a plan! I found the NI9862 to only require about 10 ma.
(3,619 Views)
