Automotive and Embedded Networks
Transmitting periodic CAN messages having different periods and different arbitration ID through single interface.
Is it possible to send multiple messages having different arbitration ID periodically (messages may have different periods) through single CAN interface?
I am using CAN frame API 2.7.5.
(4,708 Views)
What have you tried?  This is a pretty trivial piece of software.  I opened up the Transmit Receive Same Port example from Help >> Find Examples.  Then added two cases, that trasmit a frame at defined rates using the Elapsed Time express VI.
(4,694 Views)
Thanks for the idea...
Actually I need to send custom number of messages which is dynamically added, Could you please tell me how it could be done?
(4,675 Views)
I have found this vi in vi pallete.It is related to CAN object. Is it possible to use this VI to send multiple messages periodically and dynamically.
Dynamically means Some new messages will be get added during the transmission. So I need also to configure those new messages with the existing messages to transmit periodically with different periods corresponds to each message.
(4,667 Views)
Accepted by topic author ahamedalthaf1
Not all hardware support the hardware timed retransmit, so I generally stick with software timed if timing isn't super critical.  Attached is an improved version which works with an array of signals to retransmit.  Each rate is evaluated one at a time, and then that frame is sent, if enough time has passed.
(4,654 Views)
