Hi Julien,
You are correct in your observation. 1.7 to 1.8 ms is the maximum rate
with which the ncWriteNetMult() function can generate frames on the
bus, when the
Transmit Mode attribute is set to Timestamped Transmit (1, which is the preferred mode for replay type applications).
Changing the
Transmit Mode to Immediate Transmit (0) allows for
a much faster transmission of the data, however, the provided
timestamps are no longer used for timing.
Unfortunately, this restriction also applies to Series 2 CAN hardware.
-B2k
