Biomedical User Group Documents
how can i use ICA
hi guys
i want to use ICA for EEG artifact removing
but i don't know how can i remove artifacts .
i read one of labview sample about ICA but i could't understand it.
could you tell me how can i remove a noise or artifact from a signal by ICA ?
please step by step
thanks
Comments
ZJ.Gu
on
You should have a look at the Independant Components (IC) by youself or by some criteria, then remove those ICs to reconstruct the signal. In your code, ICs to remove (index) is a input you need to specifiy. For example, if you find an IC with index 5 is the noise signal (like DC drifting) you want to remove, you need add 5 in this input array.
Hope it helps.
Thanks!
ZJ Gu
Hami45
on
could you please design a simple circuit about ICA?
thanks
Mahi8337
on
hey did you find the solution for removing EEG artifacts using ICA
Contributors
