BreakPoint
LV features you wished you'd understood/used earlier
Eugh. I've finally tracked down the source of a reference leak which was causing me untold headaches on closing of an executable/VI. I'd been aware of this bug feature concern (as an old employer of mine insisted we track these things as 😉 ) for a while, but not really given much thought as to how to track it down.
Enter the Desktop Execution Trace Toolkit. Within seconds - OK, minutes, after figuring out that our corporate firewall was blocking ports 3363/3364, and changing to port 21 - I had highlighted the source of the error. In hindsight, I can see there are a number of situations where DETT would have been helpful in chasing down issues, rather than a lot of the more basic tools I usually use.
This got me thinking - are there any LV features that you wish you'd known existed sooner?
CLA
Message 1 of 12
(13,074 Views)
DETT is one of those tools I really need to play around with.  I used it breifly to try to find a memory leak.  I did find the leak, plus a lot more.
The one tool I wish I had found a lot sooner is the "switcher-roo" (or whatever you want to call it).  Hold down the CTR key with the wire tool and go over a node with two inputs.  Just a click and the wires are swapped.
GCentral
Message 2 of 12
(13,066 Views)
I think the official term is "switcheroo." Darren uses it in his Tips and Tricks presentation.
It also works with the true and false inputs of the Select function in LV 2013.
Lynn
Message 3 of 12
(13,028 Views)
You seem to imply that users understand what they use. 😄
Message 4 of 12
(13,021 Views)
A blast from the past - http://thinkinging.com/category/openg/i-couldnt-live-without/
Jim
Message 5 of 12
(12,990 Views)
Of course, you don't need to understand how a tool works to understand its uses.
jcarmody - thanks for the link!
CLA
Message 6 of 12
(12,950 Views)
@thoult wrote:
... I can see there are a number of situations where DETT would have been helpful in chasing down issues...
The DETT like the "Show Buffer Allocations" are instructive in that they show us things that may not be obvious. Once we see an issue using either tool we tend to modify our behaviour so that we do not need to use those tools again ... until we are due for our next leason.
Ben
Message 7 of 12
(12,894 Views)
Sorry, I did not intend to kill the thread.
Has anyone experimented with creating short cut-menus for libraries?
Spoiler
Create mnu... sync to directory ... include in library... Library>>>Properties>>>Select mnu will show up in short cut menu when you pop-up on a member of the library
If you have not, you may want to look into that.
Ben
Message 8 of 12
(12,815 Views)
Ben
I tried this. Gave up in the end.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 9 of 12
(12,791 Views)
You are in luck sir.  I haven't used this feature myself but the new VIPM package builder 2014 comes with this option.
http://jkisoft.com/vipm/docs/2014/index.html?turl=addpalettetolibraryorclass.htm
Message 10 of 12
(12,775 Views)
