CSLUG - Central South LabVIEW User Group (UK)
Meeting 18th May 2015 12:00-15:00
COSTEC ? Go on. I'll bite......??
Agreed,  5000 VI framework is not going to be fun to work with
Don't forget to give Kudo's for a good answer !
LabVIEW Champion
Certified LabVIEW Architect
Certified TestStand Architect
Message 11 of 59
(1,964 Views)
I was thinking more of just the QMH part, rather than the whole framework.  JKI state machine v. NI QMH template.
Message 12 of 59
(1,964 Views)
FYI, if you look at the JKI State Machine, try the UML tool's function "View VI in UML state digram..." 😉
http://www.youtube.com/watch?v=VncaD_pKe_s
Message 13 of 59
(1,964 Views)
Ah, so your framework extends beyond the QMH, I misunderstood
How about a three way comparison, JKI SM v's NI QMH v's DQMH perhaps (seeing as ours is an extension of NI's QMH and JKI's Private Events Template)
LabVIEW Champion
Message 14 of 59
(1,964 Views)
I'll step back and let you chaps sort the details. It's going to be a packed agenda I think, maybe we should declare a 3rd hour!
Steve
Opportunity to learn from experienced developers / entrepeneurs (Fab,Joerg and Brian amongst them):
DSH Pragmatic Software Development Workshop
Random Ramblings Index
My Profile
Message 15 of 59
(1,964 Views)
That's not a bad idea (3rd hour !!!)
James, what's your thoughts ?
LabVIEW Champion
Message 16 of 59
(1,964 Views)
There are two independent comparisons, really.  The communication framework of "actors" and the QMH used to implement an actor.  I could easily adapt the NI QMH into an actor in my framework, and you could use the JKI SM with JKI-style Events (as, indeed, JKI must be doing, yes?).
So, discussion points could be:
-- Differences between JKI SM and NI QMH (and I would argue strongly that the NI QMH is flawed)
-- Similarities in how you make either into an actor (I saw a recording of your 7x7 CLA presentation and was struck by the familiarity)
-- Differences between the weak-typed, text-variant-style messages of my system and the strong-typed cluster of User Events used in the JKI Public/Private Events framework.
-- James
PS I could do a third hour.
Message 17 of 59
(1,964 Views)
We could judge them by the Emery's scale. Phrase coined by Jack Dunaway at eCLA.
Message 18 of 59
(1,964 Views)
I really liked that!, in the reverse of my original plan (which was just to take the inherent framework complexity and factor it out until we had a number for the problem solving bit). Having a number for this factor is an indication of the possible complications vs complexity for the framework. I think the only thing missing is another metric for adding a requirement and then getting the number again, this would also give a scaleability metric.
Pats on the back to all of us BTW, I think any of the subjects of our presentations in isolation were something to be proud of but the quality of all of them en-masse was just great!
Steve
My Profile
Message 19 of 59
(1,964 Views)
If there's time on the 20th, I'd like to do a quick update on the Assert API, as I've made some pretty big changes to it based on feedback from the CLA Summit. I'd only need a few minutes.
Message 20 of 59
(1,964 Views)
