Counter/Timer
6602: How to use 8 counters simultaneously in C++ using traditional Daq for frequency measurement
Hi Everybody;
I'm new to Ni-DAQ cards and working on NI PCI-6602 Card in Borland C++, I should use Traditional DAQ for my project. Now I want to use all the 8 counters simultaneously for frequency measurement.
1.Where should I connect my External signal, to source or gate, at present I have connected to source.
2. How to set parameters and start the counters simultaneously, what are the parameters to be set for frequency measurement.
3.How to start counting.(parameter settings)
4.Should I set any PFI Lines or by default are they set to counters.
status = GPCTR_Set_Application (1, gpctrNum, ND_SIMPLE_EVENT_CNT)
status = GPCTR_Change_Parameter (1, gpctrNum, paramID, paramValue)
iStatus = GPCTR_Watch(1, gpctrNum, ND_ARMED, entityValue);
status = GPCTR_Watch (deviceNumber, gpctrNum,ND_COUNT, entityValue)
what is the paramID in my case, Clear and appropriate answers would be very helpful and thanks in advance.
Message Edited by Pavan K on 07-11-2009 12:38 AM
(4,622 Views)
Can any old user of labview help him in the same .
Regards ,
Ramita
(4,582 Views)
  I have made a program with LabVIEW 5.1 based on NI 6602, in which four counters were used.
  Counter 3 is used to generate pulses, which are directed to the gates of counter 0, 1 and 2.
  The source terminals of counter 0,1 and 2 receive pulses, individually, to count how many pulses appear during the time interval of each gate pulse.
  The results are stored in a data file.
  In order to test its performance, only one signal of ramdom pulses is sent to counter 0,1 and 2.
  But I find that at the beginning the counts for the three counters are the same, but the following counts are totally different!
  What's wrong? And how to solve such a problem? Does it have something related with synchronization?
  Thank you very much!
(4,113 Views)
