10-21-2009 08:24 AM
I have been successfully been able to get counter 0 and 1 working in a simple event counting mode. But when I read Software Save register for counter2/3 it gives me garbage values. I am doing register level programming in C.
This is the algorithm that I follow
In initialization:
-> Reset the Counter
-> Write32( Clock_Config_Reg, 0x00)
-> Write Load A and LoadB registers
-> Write to Input Select Register with appropriate values
-> Write16( Command_Reg, 0x0125);
Then when I need to read the SW save register value
-> Write to Command Register setting the gi_Arm bit
-> Reading the SW save register twice
-> If not equal ,read again
-> Write to Command Register disabling the gi_Arm bit
This works just fine for counter 0 and 1. But I can't get it working for counter 2 and 3. Are there any other registers I need to set up correctly for counter2/3. Is the default reset values of registers different for counter 2 and 3?
Any help would be very appreciated
10-21-2009 01:43 PM
10-22-2009 06:34 PM
Hello manisha,
Is there a particular reason for using register level programming to interact with your DAQ card, rather than the DAQmx driver? The reason I ask is because we don't support RLP at NI. There are some manuals that have been developed, such as this one which corresponds to your card, but I am unable to offer any support after that. If it is necessary that you must use RLP then you should post your question to the DDK forum, as they have more experience in this area.
10-23-2009 07:11 AM
Hi Brandon
Thanks for replying . I was able to get all 4 counters working. I think I was missing some initialization steps earlier.
Here is the manual that helped me
http://www.ni.com/pdf/manuals/340934b.pdf
Regards
Manisha
PS: Can you move this post to DDK so that other ppl may benefit if they are also doing RLP.
