05-11-2007 06:25 AM
05-14-2007 09:53 AM
Hi Jamie,
The PCI/PXI 6602 and PCI/PXI 6014 are supported by DAQmx 8.5 as mentioned here:
http://www.ni.com/support/daq/versions_pci_pxi.htm
You should not need to install the traditional DAQ drivers as well. Did Windows detect the cards when you restarted the computer after installing DAQmx? You can check from Device Manager to see if the cards are detected and installed (should be under Data Acquisition Devices). If they aren't there, then they won't show up in MAX. You can try removing the cards or replacing them in different PCI slots and see if they are detected then.
If they are installed in Device Manager, it could be a corrupted MAX database problem. You can fix that by deleting the <National Instruments folder>\MAX\Data folder and restarting the computer. Make a backup of that folder somewhere just in case.
Let me know if that works!
Way S.
NI UK Applications Engineer
