05-30-2007 02:27 AM
05-31-2007 05:14 AM
Some update information.
Now I have connected two signal generators to my daq card, one
for counter 0 and the other for counter 1. I'm testing this with the
frequency measurement example with slight modification that I
mentioned in the previous post, this example can be found from
the following address http://zone.ni.com/devzone/cda/epd/p/id/4669.
The problem is that the signal generator connected to the counter 1
does not have any influence to the measurement. The program gives
the same frequency for both counters, even if the signal generator
that is connected to counter 1 is switched off. If I take the cable off
from this signal generator, the program gives a frequency of 0 for
counter 1.
For some reason the VIs that I attach are not included in the message,
so I can't attach the actual program that I'm using for this measurement,
but it is almost the same as the VI found from the link that I provided.
All tips and hints are welcome.
