Counter/Timer
DAQmx Basics / Trouble to get pulsetrain out of NI-6612 PCIe (Simulation)
I'm a Newbie with counter/timers or any other data acquisition/generation task with hardware. So please be forgiving, when this seems to be a pretty basic question.
I am trying to get used to NI-DAQmx (without LabView). I managed to create a simulated NI-6612 Device (2 Ports, 32bit/8bit) and selftest of it is successful. I also get some sort of signals in Testpanel which I do not fully understand yet but am able to adress specific lines (PFI0-39) and put a finite/continuous signal on them by myself which makes sense to me. However, when I try to measure a pulsetrain on any of the 8 counters, the corresponding signal-to-measure-channel is already given by the internal routing as given by Pinout-Description. Given that my input-signal lies on the right channel in a separate task, nothing appears to happen when I press run. I get no error, but it does not count the edges at least. Beside that it is confusing, that some counters refer to Port1-Lines which doesn't support buffered signals at all. So I guess I have a lack of understanding how the tasks/internal routing of MAX work (although I read the manual) or what I have to do, to get the edges of my pulsetrain counted (in simulated mode).
Thank you in advance!
(3,163 Views)
Behavior of simulated devices is scripted.  Many things you might try to do to configure it differently won't have the effect you'd see on a real device.
So attempts to generate and then measure will probably produce a scripted measurement result that has no relation to what you "generated" (in a simulated way).
One other point of clarification for you: counter tasks are distinct from regular digital i/o tasks even though they receive/produce the same digital logic signals.  PFI lines cannot be used for buffered digital i/o, but they *can* be flexibly routed for counter signals.  Port 0 *can* be used for buffered digital i/o, but those lines cannot be routed for counter signals.
-Kevin P
(3,136 Views)
