Counter/Timer
Difference between CI Freq and CI Pulse Freq
I'm using a NI 9401 to collect counter data for a optical tachometer and a flow meter but I noticed there was a specific subsection of DAQmx counter channels for Pulse measurement.  I think I understand the Pulse time and pulse tick inputs but I'm not getting the Pulse freq.  Namely I don't understand how that is different than the normal CI Freq measurment.
Glancing at the LabVIEW detailed help doesn't seem to offer a clear difference that I can see. I don't suppose anyone can explain the difference or has a link to a resource explaining this in greater detail than the help document?
Richard
(6,244 Views)
Hello BikeBandit,
The CI Freq measures the frequency of a digital signal, while the CI Pulse Freq returns the frequency and the duty cycle of the signal.
Carmen C.
(6,228 Views)
Thanks for the reply Carmen.
So then the frequency measured by both could be the same I imagine?
Richard
(6,223 Views)
CI Freq predates CI Pulse Freq (which only works on STC3-based devices like X Series and cDAQ other than the 9172).  The frequency measured by each should be the same, but the pulse measurement also computes duty cycle like Carmen mentioned.
The X Series User Manual has diagrams of how each method works.  The CI Pulse Freq method results in twice the data needing to be transferred, but that's really only a concern if you are taking high frequency buffered measurements.
Best Regards,
John Passiak
(6,217 Views)
