Counter/Timer
Drive CO Timing Off of Non-TTL Clock?
I'm using a PCIe-6321. I'm trying to send a counter output for specified numbers of ticks based on an external clock coming into a PFI input.
The problem I'm having is that my external signal is not TTL, it is an AC coupled 50 ohm 1 volt signal (+/- 0.5 V about the middle). The voltage difference is too small for the DAQ to notice.
What is the best solution to this? Is there a better approach than using an external amplifier to turn the clock into something the DAQ understands (0 - 5 V signal)?
thanks,
Isaac
(5,461 Views)
Actually, to expand on my question, what are the specifications for a valid external clock signal to drive a counter? Is it basically just the DIO line TTL specifications?
Which from what I can find are:
High level, min. 2.2 V, max. 5.25 V
Low level, min 0 V, max. 0.8 V
If I go the amplifier route, I need to make sure I get something that will work and not cause damage.
thanks,
Isaac
(5,457 Views)
iBrow1000, you're correct in stating that you'll need to shift your signal. There are several approaches to solving this with varying degrees of difficulty and robustness ranging from op-amp configurations to ICs made for this purpose.
As far as not causing damage, just make sure that the supply voltage on your op-amp is something safe. Your output signal can't exceed that. This device has over protection up to 20V, so if you put in 5.5 V you should be fine.
This is a pretty good article about how to select a decent instrumentation amplifier for your application as well as avoiding some common pitfalls:
http://www.edn.com/design/analog/4322833/The-right-way-to-use-instrumentation-amplifiers
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
(5,426 Views)
Thanks for getting back to me, and for the info about the voltage protection.
Lets say that I just amplify my +/- 0.5 V signal into a +/- 5 V signal without shifting the level. Based on the +/- 20 V protection listed in the specifications, this would not damage the board and would allow normal edge counting operation. Is that correct?
thanks,
Isaac
(5,420 Views)
I would advise against it. It might be alright, but it's not a true TTL signal and the input is not expecting negative voltages. I would recommend either amplifying to +/-2.5V and then a DC offset, or you could amplify like you're intending and use a clamper circuit to only get the positive side of your signal.
Tanner B.
(5,416 Views)
The proper and most robust way of converting your signal is to use a comparator. Simply amplifying the signal, besides not having the correct voltage levels, may also not have the required edge speeds.  I have not looked at the specifications of the PFI input, but many digital input circuits do not work well with slow transitions between the high and low levels. Select a comparator with an active TTL output and everything should work well. Most op amps are too slow to make good comparators for logic circuits.
Lynn
(5,400 Views)
