Counter/Timer
FFCF273 error on NI 6624 card when using DAQmxSetCICountEdgesDigFltrEnable
I am writing a system using Borland Delphi.  I need to set the filter on a NI 6624 card to a value other than the factory-set default.  I am using the function DAQmxSetCICountEdgesDigFltrEnable.  If I set the filter value to 5.0e-6 or 1.0e-6 (representing 5 µs or 1 µs respectively), DAQmx accepts the value, but if I set it to 5.0e-7 or 1.0e-7 (500 ns or 100 ns), then an error code of FFCF273 (ErrorInvalidAttributeValue) is returned.   I assumed that maybe the original code used by NI was compiled using a non-Borland compiler and that there was an error due to rounding.  However I tweaked the lowest order, successively adding 1, then 2, then subtracting 1 then 2 from the value.  (I did this using the Delphi equivalent of the C union construction).  This did not fix the error.  Any other suggestions?
(4,468 Views)
Hi martinVI,
According to the NI 622x Specifications, the supported filter settings are "125 ns, 6.425 μs, 2.56 ms, disable". I'm not sure why 5e-6 and 1e-6 didn't error as well, because they are not supported values for DAQmxSetCICountEdgesDigFltrMinPulseWidth() on the NI 622x. What version of NI-DAQmx are you using?
If you call DAQmxGetExtendedErrorInfo(), you'll get a string that contains specific information about what caused the error, including "You Have Requested:  500.0e-9; You Can Select:  0.000000,  2.560000e-3,  6.425000e-6,  125.0e-9".
Brad
Message Edited by Brad K on 09-02-2009 12:46 PM
Brad Keryan
NI R&D
(4,446 Views)
