Counter/Timer
Hoe to use Counter for pulse train generation with higher accuracy?
For one of our project there is a requirement to generate pulse train.
Core requirement is that we have to generate a Torque Pulse follows one reference pulse & the delay of this torque pulse from reference pulse should be more precise means,
this delay should have an accuracy of ± 2ns (ns-nano seconds).
Our idea is to use counter to generate this pulse train.
I have gone through the possible solutions from NI & to achieve this accuracy thought to use NI PXIe 6356 Which is having 100MHz base clock for counters.
Since 100MHz=10ns will help me to achieve that much precise requirements of delay (multiples of 10ns will better give better accuracy).
Against to this I have some more queries which are mentioned below.
·         Since I am not using analog output which has output rate of 3.33MS/s, will it be possible to utilize 100% base clock of 100MHz for counter to generate pulse train?
      I called for support from NI & I got a reply that it is possible. So is it true?
·         What is the rise time & fall time for this one period of clock?
·         What is the possible deviation/Noise in this clock period of 10ns?
·         What could be the delay in this clock period if we trigger the counter by using LabVIEW?
·         What are the triggering sources & accuracy available internally to trigger the counter?
·         How we can achieve better accuracy by using external triggering method?
Your quick feedback on these queries will help us a lot.
E-mail me to nilesh.adat@goodrich.com also.
Thanks & Regards,
Nilesh
(4,955 Views)
Hello Glenn,
Thanks for your reply.
Actually I want to correct my first query.
  • Since I am not using analog output which has output rate of 3.33MS/s,
is it true?
-Yes, you can use the AO Sample Clock to generate a a pulse train. Keep in
mind, you probably don't need a sampled clock operation for a counter
output task. Also, you will not be able to have a 100MHz output.
I am not aware that how internal base clock is shared in DAQ card. Here I want to ask you that I am not at all using AO feature for any purpose.
So I will not use AO Sample Clock to generate a pulse train by using counter.
In this case, will there be any internal "overhead" in a system that will not allow the counter to have a base clock rate of 100MHz?
Actually my core requirement is to get a pulse with +/-2ns accuracy from counter output by using a base clock of 100MHz.
So is it possible to use this base clock with its full capability?
Nilesh
(4,937 Views)
