Counter/Timer
I meet a question for HP53131A to read parameter on screen!
I meet a question for HP53131A to read parameter on screen.It will no respond when I load a HP53131readmessage.vi directly.It can pass when I use the highlight execution.I try to add some delay.It is no any effect.Could you please to help explain why?I should how to do with this case?Would appreciate your suggestion.
(6,050 Views)
This belongs to the Instrument Control Board. This board is for NI counters.
Try using an already written driver.
(6,043 Views)
Can it make the test program run slowly when you use the highlight execuation? How to do in the test program if I want to run this execution? Can I use the delay to make the test program slowly? It is urgent. This problem take me one month and still can't finish.Do you have any suggestion?
(6,023 Views)
Of course highlight execution makes the VI run slowly.
I have no idea of your specific problem. I also don't understand your modification of the driver with the addition of what appears to be a function from a different driver. That is probably not a good idea. What is that supposed to do? It certainly does not take a measurement when you execute the other driver function.
(6,002 Views)
