Hi Anthony,
Do you need to manually adjust the stepper motor from a knob in LabVIEW? The previous example was a hardware-timed solution so you could have specific control over the rate. If the exact rate of the motor is not important, you could try out this example that I put together:
Using SW-Timed Digital I/O to Control a Stepper Motor with DAQmx
"The other John P"
John Passiak
