Counter/Timer
Timebase problems using Ctr0 (Freq. meas) from NI 6259 in DIAdem DAC
my problem is: If i use the Ctr0 input from my NI 6259 in DIAdem DAC for frequency measurement, the time in DIAdem runs "slower". 10s realtime are 10ms in DIAdem for Example.
The whole timebase is divided by 1000: The numerical outputs in "View" which actually resample with 10Hz show the new value only every 100s instead of 0,1s because the time increases in milisecond steps.
After removing the NI-DAQ Input block with the Counter Input everythings fine.
Any ideas?
Sascha Zimmer
(5,552 Views)
Hi Sascha,
can you upload a DAC-Plan were we can see what you are doing exactly and also post the file you get with the wrong time values?
That would be great,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(5,539 Views)
