Counter/Timer
setting of time delays
Is there an icon to select different delay timings?
My concern;
I want to have a list of 5 different delay timings.
So when I choose a particular delay timing and press my any-increase or any decrease button,
the point in the graphs moves accordingly to the delay timing.
I searched but could not find one to suit the need.
Please do advise.
Thks and Regards
Titano
(4,758 Views)
Hi Titano,
Sorry I am a little confused. Are you wanting to change the timing of the while loop wait?
You could do this using a simple case structure, with different cases inside.
The wait function loop, essentially changes how often the loop iterates. This however won't make any difference to the values being sent to your graphs?
Are you wanting to use "wait until?" or "wait until next multiple?" Here is an article which explains the difference.
Ashish Naik
Automotive Business Development Manager
National Instruments UK
(4,730 Views)
This is a great tutorial that will help you learn about case structures, and some other LabVIEW fundamentals
Tutorial: Timing, Shift Registers, and Case Structures
Ashish Naik
(4,729 Views)
