Counter/Timer
time base to multiply with to get signal period?
Happy Easter!
A quick question please! I have designed the vi to calculate the speed of a signal. I'm using the simulated signal to make sure it works before applying on real hardware. In this case I know the simulated frequency which is 10.1 Hz (0.099s). Using tick count I am getting rougly 16000 ticks as the period.
This VI is designed from new vi from getting started window. I have real time, fgpa and labview 2009 on my machine.
Am I successful so for?
If so, what is the timebase I multiply my 16000 ticks to get frequency? I believe I should get 0.099s to ensure I'm on the right track?
Thanks for help in advance
Cheers
(5,440 Views)
Duplicate post
Please only post once. If you have replies from other users, please follow up with them rather than starting a new thread.
Many thanks,
Andrew McLennan
(5,408 Views)
