DASYLab
2020_1 Read channel offset
I try read asc file where is 20 channel to Dasylab 2020.1 but when I try to add number 16 to channel offset in read module no 2 it will change 16 to value -5.
Can someone help with this?
(3,550 Views)
Please post a sample file with the same type of header and number of channels.
I'll take a look at it and see if I can help.
You may want to contact your DASYLab reseller directly, especially if it is a problem unique to the DASYLab 2020.1 service pack update.
--cj --DASYLab Pro -- Retired --- I am no longer employed by NI or Measurement Computing. My opinions are just that, seasoned by 25+ years of working with DASYLab. Please contact www.MeasX.com or www.mccdaq.com for active support options.
(3,486 Views)
Yes I got instructions for this from support (mcc). Apparently these new feature smartmux (this just my conclusion) causes that read -module is more accurate form of this ascii-file. Older version (2016SP2) works fine.
Luckily I found that kind of editor which can open andd edit those big ascii-files.
Attached shorter version of my ascii-file, if you also want to look that. This is exported from  EVIDAS (HBM or now HBK data acquisition soft.). I am not sure is there any settings for ascii files.
Another issue came up when I write csv file, I have to choose semicolon that data is in columns when I opened file with excel. Is this depend on setting of my operating systems?
Br Mika
(3,480 Views)
I see the problem. I hope that support (mcc) has reported it.
With regard to CSV. When you create the file and select CSV as the file extension, then DASYLab will use the regional settings to configure the data separator.
In most of Europe, the decimal separator is a comma, so a "comma separated values" file would not be able to use comma as the data separator. Excel recognizes the semicolon ( ; ) as the default data separator for CSV. That's one reason that DASYLab did not support CSV files for so many years.
When you create the file, you can specify the data separator and decimal separator.
With DASYLab 2020, the Read Data module also allows you to specify how the file is configured. I was able to easily override my regional settings (US, decimal is dot, CSV is comma) to read the file ...
But, as you say, you cannot read the upper channels.
(3,470 Views)
Hello
We see the problem and can also reproduce the error.
The problem here is that with DASYLab 2020 some additional plausibility tests have been added in the dialog, but with the given file they do not have the desired result. DASYLab always looks for a line with the number of channels in the file.
However, this is not present here, so the offset is calculated incorrectly.
For a work arround you can write the number of channels in the text file by inserting the following line as the second line:
Number of channels : 20
Then the number of channels is recognized and the offset is no longer incorrectly adjusted. With this modification, I was able to read the upper channels too.
Stephan
measX GmbH
www.measx.com
(3,444 Views)
Hello Stephan and CJ,
Thank you for your help. Now I know how to handle these files with 2020_1
Br Mika
(3,425 Views)
