12-21-2012 01:23 PM
I am thinking of purchasing either the cDAQ-9138 or cDAQ-9139. We have had good success with DASYLab on prior systems and would like to continue to use DASYLab but would like to use it in conjunction with NI C-Series modules on a Standalone cDAQ platform. I would like to hear if anyone else has any experience with DASYLab on the cDAQ 9138 or 9139 and are there any issues with interfacing with the C-Series Plug-in Modules?
12-26-2012 05:08 PM
You can post this question in the DASYLAB Online Technical Support
12-26-2012 05:15 PM
Sorry for the delay... we might have taken some time off for the holidays.
Happy New Year!
Looking at the spec for the cDAQ-9138 and cDAQ-9139 - DASYLab will require the Windows Embedded system. I do not have any personal experience with either unit.
We have not specifically tested DASYLab with Windows 7 Embedded, but have had good success with Windows XP embedded. DASYLab will not run in the RT system - you need to stick to LabVIEW for that.
You might feel a bit tight with just 2GB of RAM - but Windows Embedded may not need as much memory as standard Windows. Simply disable unneeded services and applications - run with the bare minimum needed to run the DAQ services and DASYLab application.
DASYLab does support NI-DAQmx devices.
It's possible that my colleagues in Germany will have some comments... we just have to wait for them to get back from the holiday.
01-10-2013 02:26 AM - edited 01-10-2013 02:30 AM
We have a teststand with a PXI-1042 (Pentium III (!!), 800Mhz, 128 MB, WinXPemb) that "runs" DASYLab 9 since years.
It's ok, if you define "running" as "not completely stagnant". 😉
Slow CPU + harddisk is very, very slow + not enough RAM = no fun, but works.
cDAQ-9138: dual-core Celeron >1000 Mhz, 2 GiB RAM
cDAQ-9139: dual-core i7 >1000 Mhz, 2 GiB RAM
==> Much better.
Win7 + 2 GiB RAM: Stop unnecessary applications during your DASYLab experiments.
07-03-2015 06:45 AM
today I successfully installed DASYLAB 11.0 on a cDAQ 9134 controller (standalone), additionally I intalled the NI-DAQmx device driver 14.2 and the intermediate device driver MCC.
This MCC device driver creates finally a communication between the NI-DAQmx device driver and the DASYLAB Application. I was meassuring an accelormeter, therefore I was using the C Series Module NI 9234.
Basically as soon as you can create a task in Measurement and Automation Explorer you are able to acquire or generate signals in DASYLAB.
rupido
