DASYLab
The data block queue is empty
Hi
I have a very simple case where I send values to a testrig, see attachment. The card I use is a PCI-DAC6703 from Measurment Computing. I get this error "The data queue is empty. Try decreasing the scan rate and blocksize for Dev1-Ao0". I have tried decreasing the scan rate and it and it delays the error but it still comes.
Best regards
Mats Redhammar
(7,403 Views)
I am having the same problem.  Did you ever find a fix?
(4,523 Views)
Try updating to the latest MCC-DRV 13.4 at www.mccdaq.com/software.aspx
Of course, this only works for V13.
If you have a new problem, please create a new request with details of the problem.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(4,521 Views)
