05-22-2017 06:35 PM
Hi. I'm using DASYLAb 13 on a windows 7 machine. Is there a way to prevent the DASYLAB modules to show on the screen during the worksheet loading? For very big programs the worksheet take some time to load. As a result, you observe the modules being loaded. Is there a way to show an image on the PC monitor while the worksheetit is loading?
Regards
Solved! Go to Solution.
05-23-2017 08:18 AM
You can configure the display modules to be hidden, using the View menu option "All Windows --> Hide". There is a short cut button on the function bar under the menus.
Otherwise, as the worksheet loads the modules each set themselves up and may flash as they do but will disappear once they are loaded.
