DIAdem
DIAdem wav files
Hi guys, sorry if this is the wrong place to post but hoping someone can help me out. How can I save channels as audio files? I can save wav files but they are silent, online info seems to suggest I need to scale it but I’m not sure what is required. Thanks, sorry if this isn’t appropriate here
(858 Views)
Hi, having the channels scaled means their range must be between -1 and 1.
You can save a channel in a .wav file as follows (remarks, it is Python code)
dd.DataFileSave(r'D:\Data\Signal.wav', 'Audio', True)
If you use VBS, the script should be as folllowing (not tested).
Call DataFileSave("D:\Data\Signal.wav", "Audio", True)
I tried to export a channel to .wav and it worked (I opened the .wav file anc could hear the sound).
I put a time channel t (frequency: 44100 Hz that is a standard frequency for audio files) and an associated signal channel y.
With the sample code you can find above I was able to export it as a working .wav file.
Hope it helps.
(822 Views)
