02-05-2016 01:53 PM
I'm using the OnDataStoreLoading event to grab some properties from loaded data, but I'm having a problem with the ElementListOrABS variable. The variable passed to my function by the OnDataStoreLoading event is always an object, but sometimes it doesn't support the Count property.
If I load data via the Navigator Panel, it works fint, ElementListorABS.Count works as expected. But if I load data with a script using the Navigator.LoadData command, ElementListorABS IS and object, but I get this error:
78 2:47:27 PM Error:
Incorrect instruction or user command.
In <Load_Event_OnLoading.VBS> (line: 37, column: 5):
Object doesn't support this property or method: 'ElementListOrABS.Count'
How can I check if ElementListOrABS is an object AND supports the Count property?
02-08-2016 12:39 AM
Hi RussellSenior,
I tested this behavior, but could not reproduce it. I defined this user command:
Call AddUserCommandToEvent("Navigator.Events.OnDataStoreLoading","MyOnDataStoreLoading") Sub MyOnDataStoreLoading (NaviLoadControl, ElementListOrABS, ImportAction) If IsObject(ElementListOrABS) Then Dim Element For Each Element in ElementListOrABS Call MsgBoxDisp("Element name: " & Element.Name) Next Else Call MsgBoxDisp("Event Parameter StorageABS" & VbCrLf & ElementListOrABS) End If End Sub
and checked it interactively and with this script:
dim oLoadedData, oMySelection set oMySelection = Navigator.Display.CurrDataStore.Browser.SelectedElements dim oMyPropertyImportSet set oMyPropertyImportSet = Nothing ' Minimal configuration set oLoadedData = Navigator.LoadData(oMySelection, "Load" ,oMyPropertyImportSet) ' Use this line for DataStores without GUI
Both worked fine. I used DIAdem 2015
Greetings
Walter
02-08-2016 08:19 AM
Element.Name always works for me too, it's the Element.Count property that sometimes doesn't. If you load a single item from the MeasurmentQuantity level of a database, the Element.Count doesn't work. If you load a Measurement level, it works fine.
I modified your code a little to reflect how I am doing this, and it's at the bottom. Again, I get an error if I load something from the MeasurmentQuantity level. My work around is this:
On Error Resume Next MyCount = ElementListOrABS.Count On error goto 0
If MyCount is an empty string, I know I can't use count.
Sub MyOnDataStoreLoading (NaviLoadControl, ElementListOrABS, ImportAction) If IsObject(ElementListOrABS) Then Dim i For i = 1 to ElementListOrABS.Count Call MsgBoxDisp("Element name: " & Element(i).Name) Next Else Call MsgBoxDisp("Event Parameter StorageABS" & VbCrLf & ElementListOrABS) End If End Sub
02-08-2016 08:38 AM
I used your script code and tested it with DIAdem 2015 SP1. It worked fine for TestRun, Measurement and MeasurementQantity.
Which version do you use?
Greetings
Walter
02-08-2016 09:07 AM
2014 sp1. (14.0.0f5641)
Script engine: 5.5.0.5207
02-09-2016 04:57 AM
I tested it with DIAdem 2015 SP1 and 2014 SP1 - both are working fine.
Here is my test script which works with the installed ASAM test dataset and my user command.
Dim oMyConditions Dim oMyQueryForm '--- Search without GUI Dim oMyDataStore, oMyQuery, oMyResults Set oMyDataStore = Navigator.ConnectDataStore("ASAM Pass Fail Analysis Example") Set oMyQuery = oMyDataStore.CreateQuery() oMyQuery.ReturnType = "MeaQuantity" Set oMyConditions = oMyQuery.Conditions '--- Fill the query Call oMyConditions.Add("Measurement","Test_Operator","=","George") Call oMyConditions.Add("Measurement","Test_Status","=","Fail") Call oMyConditions.Add("MeaQuantity","maximum",">=",50) oMyConditions.Logic = "C1 AND C2 AND C3" '--- Search without GUI Call oMyDataStore.Search(oMyQuery) Set oMyResults = oMyDataStore.Results Navigator.LoadData(oMyResults)
Call AddUserCommandToEvent("Navigator.Events.OnDataStoreLoading","MyOnDataStoreLoading") Sub MyOnDataStoreLoading (NaviLoadControl, ElementListOrABS, ImportAction) If IsObject(ElementListOrABS) Then Dim iLoop For iLoop = 1 to ElementListOrABS.Count Call MsgBoxDisp("Element name: " & ElementListOrABS(iLoop).Name & " - " & str(iLoop) & " of " & ElementListOrABS.Count) Next Else Call MsgBoxDisp("Event Parameter StorageABS" & VbCrLf & ElementListOrABS) End If End Sub
Please could you test it with these scripts?
Greetings
Walter
