Hi Kevin,
If you created a DirectAccessChannel for both the Date column and the Time column, then you just need to add each to a ProcessedChannel, like this:
Set DateTimeChannel = Group.Channels.AddProcessedChannel("DateTime", eTime, eAddProcessor)
DateTimeChannel.Properties.Add "UnitString", "s"
jMax = UBound(ChanNames)
Set Block = File.GetStringBlock()
FOR j = 1 TO jMax
Set Channel = Block.Channels.Add(ChanNames(j), ChanTypes(j))
Channel.Properties.Add "Unit_String", ChanUnits(j)
Select Case ChanNames(j)
Case "Date", "Time"
Call DateTimeChannel.Channels.Add(Channel)
Case ELSE
Call Group.Channels.AddDirectAccessChannel(Channel)
End Select ' ChanNames(j)
NEXT ' j
Brad Turpin
DIAdem Product Support Engineer
