DIAdem
Rechteckverlauf analysieren/ rectangular progression analyze
Hi washa001,
general settings
Option 1, one result channel
Option 2, a result channel for each match
Greetings
Walter
Message 11 of 15
(674 Views)
Hi Walter,
thank you very much for the quick reply.
I actually did the same thing as we did them. but it's not true for me.
I actually need a script for this using VBSCRIPT.
and Both the positive values and the nigative values.
here are pics for what i'm doing.
could you please write me a script for it.
Thanks in advance
Message 12 of 15
(665 Views)
Hi Walter,
I want the results only if the above 0.6 or below (-0.6) and for a minimum duration of 80 ms. if it is over 0.6 but for less than 80 ms then NOT.
the picture might show what i mean.
I can't find the appropriate commands for this, so I make a script for the automatic evaluation with VB_Script.
I hope you can help me.
Thank you very much
Message 13 of 15
(659 Views)
Hi washa001,
For this, two conditions are required, which are connected with OR
You can get the script commands for this by pressing CTRL+SHIFT+C in the opened dialog.
ChnEventList1 = ChnEventDetectionWindow("[1]/Time", "[1]/Signal", 0.6, 50, 0, 0)
ChnEventList1 = ChnEventFilter(ChnEventList1, "Peaks", 0.5, "Value")
ChnEventList2 = ChnEventDetectionWindow("[1]/Time", "[1]/Signal", -0.6, -50, 0, 0)
ChnEventList2 = ChnEventFilter(ChnEventList2, "Peaks", 0.5, "Value")
ChnEventResultList = ChnEventOperationOR(ChnEventList1, ChnEventList2)
ChnEventList1 = ChnEventResultList
Call ChnEventCreateXYChannels("[1]/Signal", "[1]/Signal", ChnEventList1)
Greetings
Walter
Message 14 of 15
(648 Views)
Hi Walter,
Thank you very much, that was helpful. I have 2 more questions please, what should be changed in code so that I get only one result channel for all events.
Is there a possibility to get the events in a table (which commands should be used here)
I actually created a report layout for the normal channel results (2D graph) and I want to extend the layout so that I can clearly see a table of events next to the graph.
I am looking forward to your answer
Best regards
Message 15 of 15
(642 Views)
