DIAdem
TDMS Chanel Display Format Numeric Time
is it possible to change the display format attribut from numeric to time per chanel in LV Code?
Best regards
Alex
(2,812 Views)
Hi Alex,
Could you please show some pictures with example of what formats do you exactly talk about?
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,752 Views)
Hi TK,
in the picture normal it is numeric and i want to change it to time in LV Code
Best regards
Alex
(2,748 Views)
You can use the TDMS Set Properties VI to set any property of a file, group, or channel. But I haven't tried it with thiat property from within LV yet. Doing so in VBS in Diadem works as intended.
Mateusz
(2,709 Views)
Accepted by topic author KTM_Lex
Hi Guys,
The channel property you want to set in LabVIEW is called "displaytype".  Note that you will need to change the numeric offset (add a constant of 60084288000) if your numeric values are typical "since 1904" LabVIEW datetime DBLs.  The "displaytype" channel property set to "Time" will tell DIAdem to display the values as datetimes, but DIAdem will assume its own "since 0 AD" offset.
Brad Turpin
DIAdem Product Support Engineer
(2,586 Views)
