DIAdem
automatic change in all pages of the report
I have a question regarding a change in the layout report.
Is there perhaps the possibility, if I have a report of about 50 pages, a change to the text object in the first page and then it will be automatically sent to all pages
Message 1 of 35
(1,738 Views)
Hi Wasim90,
You can try this here:
Greetings
Walter
Message 2 of 35
(1,722 Views)
Hay Walter,
Thank you 👍
I also have a question about the average.
I want to show mean value for each results from one channel in report, maybe there is a possibility to do that.
Best grads
Message 3 of 35
(1,703 Views)
Hi Wasim90,
I have attached an example for the legend in a 2D axis system.
Greetings
Walter
Message 4 of 35
(1,695 Views)
Hi Walter,
I tried but it didn't work. Is there perhaps an explanation for the code for mean?. So for example 0 or or "d.dd"?? I attached an example but couldn't find the right code.
Thanks in advance
Message 5 of 35
(1,691 Views)
Hi Wasin90,
If you open the legend of my example layout you should see this:
The code is
@@str(cch(Data.GetChannel(CurrChnNo),0), "d.dd")@@
CCH is a DIAdem function (details are described in the help)
Greetings
Walter
Message 6 of 35
(1,685 Views)
Hi Walter,
ok Thank you , it's worked out
Best regards
Message 7 of 35
(1,681 Views)
Hi Walter,
I would like to expand my legend, so that I can reckon the length of my events.
With the function CCh you can also calculate the span of a channel but not the length of the channel on the X axis (X axis is the time)
Is there maybe a function for it.
Best regards
Message 8 of 35
(1,672 Views)
Hi Wasim90,
In case you work with one of the latest DIAdem versions and your channel has an X-Relation then you can add a column to the legend with this content:
@@str(Data.GetChannel(CurrChnNo).XRelation.Maximum, "d.dd")@@
Or you must calculate the max value of the time channel and store this a new custom property. This property can be added to the legend like this:
@@str(Data.GetChannel(CurrChnNo).Properties("<My Property>").Value, "d.dd")@@
Greetings
Walter
Message 9 of 35
(1,661 Views)
hi walter,
Thanks for the answer.
Unfortunately it didn't work for me, this function (@@str(Data.GetChannel(CurrChnNo). XRelation.Maximum, "d.dd") @@)  gives me the maximum value. What is but just need the length (with seconds) of the events in the channel (see the picture please).
i use version 2022
Greetings
Message 10 of 35
(1,656 Views)
