DIAdem
nilibddc install dll
Hello Matt:
This is a 32-bit OS VISTA as I checked it on my properties.
I hope to get a solution soon since I would be using DIAdem for a 1,200,000 points noise analysis - let see how this fare with Origin 8.0.
Thanks.
Berns B.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
Message 11 of 16
(2,090 Views)
Hello Matt:
I've attached here the screenshot of what happens at start-up and when I attempt to use the example from within LabVIEW. I hope this also gives a clear picture of what actually happens.
Thanks.
Berns B.
Message 12 of 16
(2,071 Views)
Thank you for those helpful screenshots!  Based on the information you have given me, I see no reason why you should be unable to run DIAdem.  Have you tried installing the DIAdem software on another machine?  Also, you mentioned in one of your earlier posts that at some point you were able to have DIAdem open but that you were constrained by what LabVIEW had created within it.  Can you describe this?  Are you familiar with deleting the existing data and reloading new data from the Navigator Pane or even simply using the New Layout button from the View Pane?  These may be useful to you in the scenario where LabVIEW successfully opens DIAdem.
Message 13 of 16
(2,043 Views)
Hi Dr. Burns,
I noticed that both the screenshot files you posted show a running LabVIEW program.  Would you please post a screenshot of the error you get when DIAdem launches after you have rebooted and NOT run the LabVEW program at all?
Also, would you please post that LabVIEW VI so that we can see what it is doing?  The error message you posted claims that the LabVIEW VI passed DIAdem the ActiveX command "".  I would expect an empty command to cause trouble, but not the crash that you are experiencing.
Dr. Turpin
DIAdem Product Support Engineer
Message 14 of 16
(2,035 Views)
Hello Dr.Turpin:
The screenshots I did was when everything seemed to stall after many minutes of waiting (5 minutes and more) that all I see is this (see attached). When however, after I launched LabVIEW (concurrently with a stalled boot of DIAdem) and calls *any supplied example in search example for DIAdem* this consequently happens - it loads its GUI performs what ever example I launch to the end! (say format and print a report in PDF) - then I could navigate around the GUI sub-tabs but can't make any new layout, buttons appear  but they can't be pressed or activated. If I exit the example all the rest of DIAdem GUI also diminishes. I have also tried to repair/reinstall MS Office 2007 for possible Excel errors.I have tried to examine the behavior of it and taken a look at the processes at this state (see more attachments).
By the way? Does this software have any conflicts with VC++ and VB Express Editions by the way or in anyway with other Microsoft programming modules? Is this known?
Thank you for your attention.
Berns B.
Message 15 of 16
(2,025 Views)
Hi Dr. Berns,
I would like to debug the problem you're seeing by trying a much simpler test than what you actually want to do.  I understand that you want to call DIAdem programmatically from LabVIEW in order to create some reports.  This extra ActiveX connction you are using from LabVIEW is adding a lot of complexity and unknowns to the situation and is making it harder for me to help you.  If you would like me to help you, please follow the below debugging steps.  Once we have a better idea what the source of the trouble is, we can go back to calling DIAdem from LabVIEW via ActiveX and fix any problems that persists on that end.  I want to find out whether the problem occurs inside of the DIAdem launch or because of the LabVIEW ActiveX connection.
1)  Please send me the LabVIEW VI that is communicating with DIAdem (the one in all the screenshots).
2)  Please reboot your computer, then start DIAdem from the Windows START menu, and take a screenshot of any error message that appears during this simple, stand-alone DIAdem launch.  Please then tell me what happened and send me the screenshot if an error occurred.
Talk to you again soom,
Brad Turpin
Message 16 of 16
(2,007 Views)
