DQMH Consortium Toolkits Feature Requests
Olivier-JOURDAN
Add module description field to Add New DQMH Module window
Status: Released
When creating new module, I'd like a way to add a text explaining its responsibility. It will reinforce good conception practices and allow Antidoc to retrieve information to generate a valuable documentation.
Note: IMO, this content should be added to the module lvlib description.
If this field could optionally mandatory to create the module, I would find this great 🙂
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
1 Comment
Olivier-JOURDAN
Status changed to: Released
Olivier Jourdan
