During initializing, the window is open, center and the title is change. Those operations are very slow in RT target (4 seconds on my cRio).
![Nico_EMC_2-1643964316842.png Nico_EMC_2-1643964316842.png](https://forums.ni.com/t5/image/serverpage/image-id/298125i387ADDB650863BF8/image-size/large?v=v2&px=999)
It is much faster if I disable them with a Conditional Disable Structure.
Could it be like this in the template?
Hey Nicolas, thank you so much for your trust in DQMH and for taking time out of your day to share your idea with us.
The module template feature allows developers to solve this kind of issue without waiting for a new version of the framework.
We suggest creating a template with the Conditional Disable Structure in the Initialize case for this specific use case. Once created, you'll be able to add modules using this template as a starting point.
So, we decline this request, at least for the next DQMH version.
Again, thank you for your input; it is most appreciated. Please keep those ideas coming!
