DQMH Consortium Toolkits Feature Requests
jdebuhr
Multiple selection When Validating a Project and applying updates
Status: Development Started
It is not a so good idea because it forces you to check and understand all the validations/fixes by going through them one by one.
However, we recognize that when you've seen them once or twice, it becomes painful to not be able to apply them all at once. Maybe the "Apply all" button could be visible only after you've been through them one by one first, through a LabVIEW.ini token.
Instead of selecting each item to be updated then click update. It would be nice to have an update all or be able to select multiple items to be updated.. Especially when going to a newer version (like 4.x to 5.0)
Jeff D.
Certified Architect LabVIEW Champion DQMH Framework
1 Comment
Olivier-JOURDAN
Status changed to: Development Started
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
