DQMH Consortium Toolkits Feature Requests
Darren
Validate test for mismatch between Main VI connector pane and VI reference constant in Start Module VI
Status: Declined
We must decline this feature request due to tech limitations of LabVIEW scripting 😞
If you want to pass a parameter to your module when it starts, you can add that parameter as an input to Start Module VI:
The way you define the type of the Call By Reference node (to accept the new parameter) is usually by dragging the Main VI into the VI Reference constant wired to Open VI Reference. However, sometimes a different VI may be used to define the type, especially if there are multiple DQMH Modules in your project that take the same inputs on initialization. Also, the opposite situation can occur where you add an input to the Main VI connector pane, but forget to add that input to the Start Module VI.
If the connector pane of the Main VI doesn't match the VI Reference constant in the Start Module VI, you will receive an error when attempting to start the module. I propose that we add a Validate Module test that detects this situation (connector panes of Main VI and VI Reference constant don't match) and returns a validation failure.
2 Comments
Olivier-JOURDAN
Status changed to: Released
Thank you for the suggestion.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
Olivier-JOURDAN
Status changed to: Declined
Olivier Jourdan
