Where are MGI Panel Manager DQMH panels installed?
Using VIPM, I have installed this toolkit extension (LV2023, DQMH 7.0 installed), but the MGI panel templates don't show up when attempting to create a new DQMH module. How can I validate if the templates were actually installed, and is there a way I can do this manually?
_____________
Creator of the BundleMagic plugin for LabVIEW!
(126 Views)
I see the module templates when I install the latest version of the MGI Panel Manager with DQMH:
You can verify they are installed by ensuring the following files exist on your system:
[LabVIEW Data]\DQMH Module Templates\MetaData\Cloneable Panel.xml
[LabVIEW Data]\DQMH Module Templates\MetaData\Singleton Panel.xml
[LabVIEW Data]\DQMH Module Templates\Source\MGI\Cloneable Panel\*
[LabVIEW Data]\DQMH Module Templates\Source\MGI\Singleton Panel\*
If you don't know where the LabVIEW Data folder is on your system, you can find out at Tools > Options > Paths > Default Data Directory.
Note that there were some issues with the MGI Panels not having been updated to be compatible with recent DQMH releases. I remember hearing there were some plans in the works to update them, but I don't know if that's happened yet. You may want to run the DQMH Validate Module tool on MGI Panel modules you create.
(113 Views)
