When I drop a DAQmx Task constant on my LabVIEW block diagram, I have the right-click menu option to Generate Code >>Configuration
This scripts out a sub.vi that creates the Task by adding each channel with channel specific properties sequentially, one channel at a time, to repeated calls of DAQmx Configure Channel.vi.
I have a hard time saving that vi output! I have not really learned how to name it properly without Using: "BLEEP_BLEEP_BLEEP_Configuration_that_cannot_be BLEEPING_scaled.vi"
I believe that an autoindexing loop would be much nicer.
My grandmother thanks you for improving my manner of speach.
