Background question here:
http://forums.ni.com/t5/Multifunction-DAQ/Channel-Calibration-information/m-p/1295908
Channel calibration in MAX is too limited to be very useful. According to NI AE, from MAX you can only create a table for calibration, not a polynomial fit. I assume intermediate values are linearly interpolated, but that wasn't specified. Programmatic calibration to enable polynomial cal as described in the above listed topic makes traceability problematic.
I propose that the channel calibration capabilities in MAX be amended to allow the user to select calibration mapping, either TABLE or POLYNOMIAL FIT.
OF course, the user should be able to select the polynomial order, and the R-value should be clearly indicated.
All of these properties should be included in any report generated from MAX.
