Data Acquisition Idea Exchange
Vinu5
DAQ Device pinouts Property node
Status: New
Hi, It would be useful if daqmx has a property node to read the device pinouts.
2 Comments
crossrulz
Knight of NI
I am curious what your use case is here.  What format should the data be in?  How would you use this information in an application?
GCentral
Vinu5
Here my case is I have a PXIe-6365 module which has 144Analog Inputs, we are developing an application that helps the operator to connect the UUT test points to SCB68.
While my application is running I would like to inform the operator about the channel connectivity, Refer to the image captured from NI Max
