Attempting to add a channel (Ch8) to an existing task which already uses that channel as a result of having already assigned its paired differential channel (Ch0) results in that channel correctly not being added to the task but also does not generate a warning or error. Thus when attempting to configure a task with 2 channels as Ch0 differential and Ch8 RSE, the resulting task only contains 1 channel. This may be not be apparent because the channels 0 and 8 appear as different from each other. Having a warning could give notification of this fact.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KxoSAE&l=en-US
