Data Acquisition Idea Exchange
Steverhnm
Getting the "raw" or "unscaled" voltage from DAQmx Pressure Bridge VI
Status: New
I am new to posting ideas, so I posted this someplace else and now see this is the more appropriate form for my need.....
My customer wants to be able to calculate mV/Pascal at various pressures to make sure the response is linear over the range.  The problem is I have not been able to find a VI or property node that will give me access to the raw voltage of the input signal when using the DAQMx Pressure Bridge VI, which I would then calculate the actual voltage measured vs Pascals measured.  I find it amazing that I can't easily get this raw voltage from a property node.  I do NOT want to use the Analog Measurement (as suggested by my NI service request 2399613) and then do all the translation to pressure because that would aliminate all the great stuff the Pressure Bridge Measurement VI takes into account.
